It is currently Sat Feb 22, 2025 10:25 am
 Post subject: demo guitar build
PostPosted: Thu Dec 08, 2011 9:14 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I needed something to occupy myself between customers (which there isn't very many of), and something to show potential customers for commissions, so I decided to make a demo guitar. I chose a OM style cutaway because I felt the smaller body and deeper waist allows for a better looking cutaway, and I wanted to try something other than a Dreadnaught anyways.
unlike in the West sourcing birch plywood with high ply count is impossible. Sure I could order the stuff but since I needed a lot of them for making jigs, the cost tends to be very high. Instrument wood is no problem of course, because I don't need as much of them.
I start with the neck blank since I needed to set the preliminary neck angle:
I had a very dull bandsaw blade so the cut skewed by a fair bit, so I had to do a lot of planing to correct it.
I've used hide glue for all construction, because I wanted to see how it would hold up. However I would still use titebond for things requiring more open time.
I then leveled one side and the top of the neck blank. I had to make sure both of these faces are squared to each other, but in doing so I actually angled both faces a bit, although they are square to each other.
Not wanting to order additional materials, I made my own kerfed lining.
The heel/end block and the neck blank was prepared.
Moving onto the plates, I had a set of rosewood back and side sitting around for a year or so, I also had a set of sitka top but the grain runout was horrible, something like over 30 degrees. Not only that, the grain was sort of wavy and the quarter was very off (also around 30 degrees), so after planing them to thickness, I realized it wouldn't make a good top and scrapped it, instead decided to use some of the nicer German Spruce top I just bought...
I forgot to shoot photos of these step but I had been thicknessing the side, back, and top, and fingerboard. I made a backstrip by cutting out a 1/4" strip of a maple back material then laminating them with some maple and rosewood veneer. Like I said, I don't want to order additional material if possible...
This is what the guitar will have:
Body: OM cutaway style
Top: AA Grade German Spruce top
Back/Side: Indian Rosewood
Fingerboard/Bridge: Gaboon Ebony
Binding and trims: maple
Rosette: still thinking, possibly a contrasting wood rosette.
Neck: Khaya Mahogany
Typhoon Guitars
 Post subject: Re: demo guitar build
PostPosted: Fri Dec 09, 2011 12:11 am
City: chicagoland
State: illinois
thanks for the photos; nice to see the process in detail for those who have yet to build an acoustic. the black marker makes me cringe a bit, but i assume you don't use it anywhere near "final" wood
PostPosted: Fri Dec 09, 2011 12:17 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
The black marker is used in portions of the wood where it will be sanded off... I use them so that I don't make a mistake because I can't see the marking.
Typhoon Guitars
PostPosted: Fri Dec 09, 2011 9:27 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Fingerboard planed and leveled
Cutting off the bad portion and setting the nut position
Slotting fingerboards, took a long time and arm was very sore.
Finished slotting the fingerboard
Typhoon Guitars
PostPosted: Sat Dec 10, 2011 9:45 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Finished thicknessing the back. It still have some tear outs from the plane, but it will be sanded out later.
Typhoon Guitars
PostPosted: Fri Dec 23, 2011 7:16 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Bending binding and sides:
Typhoon Guitars
PostPosted: Sat Dec 31, 2011 9:19 am
First name: Big
Last Name: Jim
Nice work there ! [clap] I dont use a hand Plane , I have tried and mess up everthing i touch with it laughing6-hehe
PostPosted: Sat Feb 11, 2012 11:52 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I am sorry for not updating for a while, here are a bunch more pictures:
Typhoon Guitars
PostPosted: Sat Feb 11, 2012 11:56 am
First name: Tony
Last Name: C
City: Brooklyn
Nice box!
http://www.CostaGuitars.com
PMoMC
PostPosted: Sat Feb 11, 2012 12:04 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Tony_in_NYC wrote:
Nice box!
Don't mind the soundboard... the German spruce does dirty easily, but I've protected the whole soundboard with a light coat of shellac to prevent it from staining the wood too deeply...
Typhoon Guitars
PostPosted: Tue Feb 14, 2012 5:37 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Neck complete and inlaid
Typhoon Guitars
PostPosted: Wed Feb 15, 2012 11:46 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Nice guitar on the way!
The bigger advantage of using a go-bar, is the easy access to clean the glue before it dries. You should take advantage of it.
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Thu Feb 23, 2012 7:09 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Guitar is ready for finishing (I plan on oiling the neck with Tru Oil, and french polish the body)
Typhoon Guitars
PostPosted: Mon Jun 18, 2012 10:13 pm
Last Name: Kelly
City: Lake Katrine
Zip/Postal Code: 12449
Can you tell me what radius' you used, back and front,,,,did you use white glue for the whole box or hide glue on the top and back?
Nice job,,,how much time did you have into it?
Regards
Joe
PostPosted: Mon Jun 18, 2012 10:16 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Regards
Joe
I used hide glue for everything except for closing the box, neck and heel blocks, and fingerboards. In that case I used titebond I.
Front and back radius is 25' but I am thinking of using a flatter radius for the top because I keep ending up with gap under the fingerboard that I don't quite know what to do about. The trouble is fitting a wedge under the fingerboard, I can't produce an exact fit without a lot more time just fitting one joint.
I haven't counted the exact hour but I started in December and finished end of April.
Typhoon Guitars
